Do-a-thon: Julia models for Energy system optimization
As a discussion basis the do-a-thon will start with a 10 min input-talk that compares the data flow for a simple 3-bus generator/storage/network example in EnergyModels.jl, PowerSystems.jl/PowerSimulation.jl (refactor-branch), PSA.jl and PowerModels.jl (and probably Joulia.jl).
The comparison should be helpful for some previously proposed do-a-thons, especially about PowerDynamics.jl (@Sabine_elena, @timk) and maybe the one about the PandaPower<->PowerModels.jl bridge (@leon.thurner).
We’ll then aim at two more steps.
1. Dicuss and formulate best-practices for
- handling electricity system parameters (input data):
explicit types for single elements (PowerModels/PowerSystems) <-> tables with conventions for classes of generators (EnergyModels/PSA).
- choosing the model formulation using dispatch on type hierarchies like PowerModels (
DCPPowerModel/ACPPowerModel) or PowerSimulation’s (Dispatch- and
CommitmentForm).
- (conventions for storing and managing the associated jump variables and
constraints)
- retrieving and storing solution data
Hopefully, we’ll be convinced that the PowerSystems.jl/...Simulation.jl
momentum is big enough (and the memory overhead solvable enough), that in the
2. Adjoining hack-a-thon
- We open tickets on their project for features missing for our concrete projects.
- We start the implementation of exporters/importers to
PowerSystems.jl from
PyPSA and other interested frameworks.
Outcomes
- Wiki entry about Best practices for Julia models with details about the model differences
- Tickets on
PowerSystems.jl/PowerSimulation.jl for feature “requirements” (requests).
Documentation of do-a-thon
Slides and notebook version 2: EnergyOptimizationInJulia.zip (62.2 KB)
The principal output has been the following table. I’ll try to provide a bit more detail over the next week.
| Â |
Joulia |
PowerModels |
PowerSystems/PowerSimulation |
EnergyModels |
| Storage of |
| - Parameters |
Flat types: Nodes, Lines, PowerPlants, RenewableEnergySource, Storages, which contain dictionaries for each parameter indexed by names |
Matpower files are parsed into a nested structure of dictionaries. ref() - Getter helps with access |
Nested detailed type hierarchy to hold data for individual components in PowerSystems.jl, possibility for extension, importers from matpower and raw |
Parameters are fetched on demand from a NetCDF backend as flexibly dimensioned DenseAxisArrays |
| - Variables |
Inside JuMP Model: model[:MarketClearing]
Variables and Constraints are equally sorted into nested dictonaries using the helper functions var() and con()
Stored in dictionary on canonical_model.{variables,constraints} mapping a chosen symbols to DenseAxisArrays |
Variables and constraint are stored on the JuMP model with a dedicated prefix involving the class name |
| Primary focus/features |
Economic dispatch with thermal and renewable generators, storage units including linearized powerflows (based on PTDF) |
Framework for reference implementations and easy comparison of several power flow formulations, with extensions for several timesteps, storage und network expansion |
Production cost modelling with flexible device model representations, Priority focus has been on operational models, Capacity expansion is coming up, integration with PowerDynamics is planned |
Co-Optimization of transmission, storage and generation capacities under linearized optimal power flow constraints for large networks |
