(repost/ new Topic from Modelleing a two way transformer with an investment object in oemof - #4 by Phil)
first of all I wanted to build an energy system like this:
Lignite source >> lignite_bus >> Lignite powerplant >> electricity_bus >> El_Demand
Gas source >> gas_bus >> Gas boiler >> thermal_bus >> Th_demand
solar source >> solar_
[my_model_without_Lig.txt|attachment](upload://2gD87whVBRp158uvu4kZtWRxXON.txt) (115.9 KB)
[my_model.txt|attachment](upload://jwL8X2fDDLQL9jYl5twoUcK2Rmn.txt) (150.6 KB)
bus >> PV powerplant >> electricity_bus >> El_Demand
Gas source >> [gas_bus, methane_bus] >> Gas powerplant >> electricity_bus >> El_Demand
Gas powerplant >> thermal_bus >> Th_demand
electricity_bus >> Methane powerplant >> methane_bus
methane_bus >> Methane Storage >> methane_bus
I implemented the Gas-powerplant like this:
trsf = solph.Transformer(
label='pp_gas',
inputs={gas_bus: solph.Flow( investment=...),
methane_bus: solph.Flow( investment=...)},
outputs={electricity_bus: solph.Flow(), thermal_bus: solph.Flow()},
conversion_factors={electricity_bus: 0.3, thermal_bus: 0.5,
gas_bus: 1, methane_bus: 1})
But it seems that there is no way for oemof to solve this problem. Even with more than enough capacity in Gas and PV and expensive lignite costs, the System is not using the Gas-PP or produces Methane.
If i run the Simulation without Lignite, the System should produce methane with PV at daytime and use the methane in the Gas PP at night or just use the Gas-PP with natural gas only.
However, it does not consume gas and calls a ValueError because the demand cannot be met
ValueError: No value for uninitialized NumericValue object flow[pp_gas,electricity-BUS,0]
In the LP-Files the methane input is implemented.
my_model.txt (150.6 KB) #(Model with lignite PP >> working)
my_model_without_Lig.txt (115.9 KB) #(Model without lignite PP >> not working)
My idea to solve this Problem, was to split the gas power plant. In one with a gas input and one with a methane input. But both must have the same investments and a combined maximum output-flow.
So I wanted to add a investment constraint.
I tried
om.InvestmentFlow.investment_costs.expr(invest[i, o])
from
https://oemof-solph.readthedocs.io/en/latest/reference/oemof.solph.html?highlight=investmentflow#oemof.solph.blocks.investment_flow.InvestmentFlow
But I don’t understand the command correctly and the output is always the complete investment of alle powerplants.
Do you have a solution for the main-problem or the investment problems?
Greetings
Philipp
