Modelling nonlinearities:
Losses (either charge/discharge efficiency or self-discharge rate) in batteries can be approximated as linear for some applications, e.g. LiIon for residential or grid (but not so big)
How does that apply to batteries: depending on battery system
§ LFP Li-Ion is quite linear
§ Lead Acid is highly non-linear
§ Degradation being one of the main problems
§ Offering of data by Holger Hesse -
Vehicles to grid - there the nonlinearity does count → you can linearise
TUM-EES building a detailed battery model - open source release to come - www.ees.ei.tum.de/simSES
Rainfall algorithm: state of the art approach and matches experimental results well (but no histeresys effects accounted for) -
PYPSA linked to a battery model
The multitude of influencing parameters makes it hard to interpret results on the effect of degradation and other stuff (VIBESUM)
Mention of study, that concludes not to use current LiIon for large energy storage, since the degradation is too prevelant (Seattle)
Long-term, seasonal storage:
- PSR Brazil 1979, Pereira SDDP - Stochastic dual dynamic programming
- Concrete: how to manage the problem of rolling horizon with taking the cumulated storage capacity to next interval
- Remention of minima at end of interval with framework to move data from one interval to next
- How to make the model choose between short- and long-term storage? Assigned higher virtual emissions to the least efficient one (long-term storage)
Load shifting as short-term storage; problem is lack of data; there’s one implementation with OSeMOSYS; UK market
- Open EGo: Acatech
Cost of Storage - Data sources for prices of different storage technologies:
- JRC ETRI, 2014
- Deloitte, Electricity storage, technologies, impacts and prospects
Heat storage: Group in TU Wien - probably energy economics group
