I wrote a piecewise object for oemof and I recognised some performance problems. The computer can solve this model really fast, but the result processing takes forever (multiple days). I saw that my piecewise object creates lots of indexed variables, which seems ok, but I think this is the reason why the processing takes so long.
Does anyone know how to speed up the processing?
This codesegment is way to slow for my model:
var_dict = {(str(bv).split('.')[0], str(bv).split('.')[-1], i): bv[i].value
for bv in block_vars for i in getattr(bv, '_index')}
This is the piecewise object:
class GasBus(Bus):
def __init__(self, *args, **kwargs):
super().__init__(*args, **kwargs)
self.slack=kwargs.get('slack', False)
self.p_max = kwargs.get('p_max', 1000)
self.p_min = kwargs.get('p_min', -1000)
class GasLineBlock(SimpleBlock):
CONSTRAINT_GROUP = True
def _create(self, group=None):
if group is None:
return None
m = self.parent_block()
self.GASLINE_PL = Set(initialize=[n for n in group])
self.GAS_BUSES = Set(initialize=[s for s in m.es.nodes if isinstance(s, GasBus)])
self.pressure=Var(self.GAS_BUSES, m.TIMESTEPS, bounds=(0,1))
self.delta_pressure = Var(self.GASLINE_PL, m.TIMESTEPS, bounds=(-1,1))
self.energy_flow = Var(self.GASLINE_PL, m.TIMESTEPS)
for n in self.GASLINE_PL:
for t in m.TIMESTEPS:
for ob in list(n.outputs.keys()):
if ob.slack == True:
self.pressure[ob,t].value=1
self.pressure[ob,t].fix()
for ob in list(n.inputs.keys()):
self.piecewise=Piecewise(self.GASLINE_PL,
m.TIMESTEPS,
self.energy_flow,
self.delta_pressure,
pw_pts=[-1, 0, 0.25, 0.50, 0.75, 1],
pw_constr_type='EQ',
pw_repn='CC',
f_rule=[0, 0, 0.50, 0.707107, 0.866025, 1, 3.1628])
def flow_eq_pressure(block,n,t):
expr = 0
expr += (self.pressure[list(n.outputs.keys())[0],t]-self.pressure[list(n.inputs.keys())[0],t])
expr += self.delta_pressure[n,t]
return expr == 0
self.flow_eq_pressure = Constraint(self.GASLINE_PL, m.TIMESTEPS, rule=flow_eq_pressure)
def energy_flow_out(block, n, t):
expr = 0
expr += - m.flow[n, list(n.outputs.keys())[0], t]
expr += self.energy_flow[n,t]*n.K_1
return expr == 0
self.energy_flow_out = Constraint(self.GASLINE_PL, m.TIMESTEPS, rule=energy_flow_out)
def energy_flow_in(block, n, t):
expr = 0
expr += - m.flow[list(n.inputs.keys())[0],n, t]*n.conv_factor
return expr == 0
self.energy_flow_in = Constraint(self.GASLINE_PL, m.TIMESTEPS, rule=energy_flow_in)
class GasLine(Transformer):
self.conv_factor = kwargs.get('conv_factor', 1)
self.K_1=kwargs.get('K_1')
self.input_list = list(kwargs.get('input_list', []))
self.output_list = list(kwargs.get('output_list', []))
if len(self.inputs) > 1 or len(self.outputs) > 1:
raise ValueError("Component GasLine must not have more than \
one input and one output!")
def constraint_group(self):
return GasLineBlock
If anyone has an idea how to speed things up I would be very thankfull.
Best, Philipp
