Hey together,
i’m new at oemof and tried to install it under windows 10 with WinPython, version 3.8.5.
I followed the YouTube Tutorial from the oemof-homepage step-by-step.
Installing WinPython itself shouldn’t be the problem, but after typing “pip install oemof” in the Command Prompt the following errors appeared (Errors: last 7 Rows of following block):
C:\Users\tlabr\Python\WPy64-3850\scripts>pip install oemof
Collecting oemof
Using cached oemof-0.3.2-py3-none-any.whl (75 kB)
Collecting numpy<1.18,>=1.7.0
Downloading numpy-1.17.5-cp38-cp38-win_amd64.whl (12.7 MB)
|████████████████████████████████| 12.7 MB 6.4 MB/s
Collecting pandas<0.26,>=0.18.0
Downloading pandas-0.25.3-cp38-cp38-win_amd64.whl (9.4 MB)
|████████████████████████████████| 9.4 MB 3.3 MB/s
Collecting pyomo<5.7,>=4.4.0
Using cached Pyomo-5.6.9-py2.py3-none-any.whl (2.5 MB)
Requirement already satisfied: networkx<3.0 in c:\users\tlabr\python\wpy64-3850\python-3.8.5.amd64\lib\site-packages (from oemof) (2.4)
Requirement already satisfied: blinker<2.0 in c:\users\tlabr\python\wpy64-3850\python-3.8.5.amd64\lib\site-packages (from oemof) (1.4)
Collecting dill<0.4
Using cached dill-0.3.2.zip (177 kB)
Requirement already satisfied: pytz>=2017.2 in c:\users\tlabr\python\wpy64-3850\python-3.8.5.amd64\lib\site-packages (from pandas<0.26,>=0.18.0->oemof) (2020.1)
Requirement already satisfied: python-dateutil>=2.6.1 in c:\users\tlabr\python\wpy64-3850\python-3.8.5.amd64\lib\site-packages (from pandas<0.26,>=0.18.0->oemof) (2.8.1)
Collecting PyUtilib>=5.8.0
Using cached PyUtilib-6.0.0-py2.py3-none-any.whl (254 kB)
Requirement already satisfied: ply in c:\users\tlabr\python\wpy64-3850\python-3.8.5.amd64\lib\site-packages (from pyomo<5.7,>=4.4.0->oemof) (3.11)
Requirement already satisfied: appdirs in c:\users\tlabr\python\wpy64-3850\python-3.8.5.amd64\lib\site-packages (from pyomo<5.7,>=4.4.0->oemof) (1.4.4)
Requirement already satisfied: six>=1.4 in c:\users\tlabr\python\wpy64-3850\python-3.8.5.amd64\lib\site-packages (from pyomo<5.7,>=4.4.0->oemof) (1.15.0)
Requirement already satisfied: decorator>=4.3.0 in c:\users\tlabr\python\wpy64-3850\python-3.8.5.amd64\lib\site-packages (from networkx<3.0->oemof) (4.4.2)
Collecting nose
Using cached nose-1.3.7-py3-none-any.whl (154 kB)
Building wheels for collected packages: dill
Building wheel for dill (setup.py) … done
Created wheel for dill: filename=dill-0.3.2-py3-none-any.whl size=78976 sha256=d1466f8cacea66d6a592c34b5de09d4a00c08f2acbf0468f535b5086fb3506ff
Stored in directory: c:\users\tlabr\appdata\local\pip\cache\wheels\93\7f\7d\78ec535a4340ef2696aad8b17fe8bb063d56301bd62881b069
Successfully built dill
Installing collected packages: numpy, pandas, nose, PyUtilib, pyomo, dill, oemof
Attempting uninstall: numpy
Found existing installation: numpy 1.19.1+mkl
Uninstalling numpy-1.19.1+mkl:
Successfully uninstalled numpy-1.19.1+mkl
Attempting uninstall: pandas
Found existing installation: pandas 1.1.0
Uninstalling pandas-1.1.0:
Successfully uninstalled pandas-1.1.0
ERROR: After October 2020 you may experience errors when installing or updating packages. This is because pip will change the way that it resolves dependency conflicts.We recommend you use --use-feature=2020-resolver to test your packages with the new resolver before it becomes the default. vega 3.4.0 requires pandas<2.0.0,>=1.0.0, but you'll have pandas 0.25.3 which is incompatible. plotnine 0.7.1 requires pandas>=1.1.0, but you'll have pandas 0.25.3 which is incompatible. mizani 0.7.1 requires pandas>=1.0.0, but you'll have pandas 0.25.3 which is incompatible. Successfully installed PyUtilib-6.0.0 dill-0.3.2 nose-1.3.7 numpy-1.17.5 oemof-0.3.2 pandas-0.25.3 pyomo-5.6.9
After that I first tried to upgrade pandas, so 1.1.1 got installed - but the following error appeared:
C:\Users\tlabr\Python\WPy64-3850\scripts>pip install pandas --upgrade
Collecting pandas
Downloading pandas-1.1.1-cp38-cp38-win_amd64.whl (9.6 MB)
|████████████████████████████████| 9.6 MB 147 kB/s
Requirement already satisfied, skipping upgrade: pytz>=2017.2 in c:\users\tlabr\python\wpy64-3850\python-3.8.5.amd64\lib\site-packages (from pandas) (2020.1)
Requirement already satisfied, skipping upgrade: numpy>=1.15.4 in c:\users\tlabr\python\wpy64-3850\python-3.8.5.amd64\lib\site-packages (from pandas) (1.17.5)
Requirement already satisfied, skipping upgrade: python-dateutil>=2.7.3 in c:\users\tlabr\python\wpy64-3850\python-3.8.5.amd64\lib\site-packages (from pandas) (2.8.1)
Requirement already satisfied, skipping upgrade: six>=1.5 in c:\users\tlabr\python\wpy64-3850\python-3.8.5.amd64\lib\site-packages (from python-dateutil>=2.7.3->pandas) (1.15.0)
Installing collected packages: pandas
Found existing installation: pandas 0.25.3
Uninstalling pandas-0.25.3:
Successfully uninstalled pandas-0.25.3
oemof 0.3.2 requires pandas<0.26,>=0.18.0, but you'll have pandas 1.1.1 which is incompatible.
Successfully installed pandas-1.1.1
Oemof itself cant work with the upgraded pandas, so I downgraded pandas back to 0.25.3.
After that, I installed the CBC-Solver for Win64 and addet it to “PATH” at the advanced system-setting.
After restart, I tried running “oemof_installation_test”, but it doesn’t show the right result, the following errors appeared:
C:\Users\tlabr\Python\WPy64-3850\scripts>oemof_installation_test
File "C:\Users\tlabr\Python\WPy64-3850\python-3.8.5.amd64\lib\runpy.py", line 194, in _run_module_as_main
return _run_code(code, main_globals, None,
File "C:\Users\tlabr\Python\WPy64-3850\python-3.8.5.amd64\lib\runpy.py", line 87, in _run_code
exec(code, run_globals)
File "C:\Users\tlabr\Python\WPy64-3850\python-3.8.5.amd64\Scripts\oemof_installation_test.exe\__main__.py", line 4, in <module>
File "C:\Users\tlabr\Python\WPy64-3850\python-3.8.5.amd64\lib\site-packages\oemof\tools\console_scripts.py", line 19, in <module>
File "C:\Users\tlabr\Python\WPy64-3850\python-3.8.5.amd64\lib\site-packages\oemof\solph\__init__.py", line 1, in <module>
from oemof.solph.network import (Sink, Source, Transformer, Bus, Flow,
File "C:\Users\tlabr\Python\WPy64-3850\python-3.8.5.amd64\lib\site-packages\oemof\solph\network.py", line 20, in <module>
from oemof.solph import blocks
File "C:\Users\tlabr\Python\WPy64-3850\python-3.8.5.amd64\lib\site-packages\oemof\solph\blocks.py", line 13, in <module>
from pyomo.core import (Var, Set, Constraint, BuildAction, Expression,
File "C:\Users\tlabr\Python\WPy64-3850\python-3.8.5.amd64\lib\site-packages\pyomo\core\__init__.py", line 11, in <module>
from pyomo.core.expr import *
File "C:\Users\tlabr\Python\WPy64-3850\python-3.8.5.amd64\lib\site-packages\pyomo\core\expr\__init__.py", line 36, in <module>
from .calculus.derivatives import differentiate
File "C:\Users\tlabr\Python\WPy64-3850\python-3.8.5.amd64\lib\site-packages\pyomo\core\expr\calculus\derivatives.py", line 3, in <module>
from pyutilib.enum import Enum
ImportError: cannot import name 'Enum' from 'pyutilib.enum' (C:\Users\tlabr\Python\WPy64-3850\python-3.8.5.amd64\lib\site-packages\pyutilib\enum\__init__.py)
It seems like Enum isn’t installed, but the folder “enum” ist downloaded with the files "init and “init.cpython-38”.
Now I have no idea, how to get oemof running.
Could anyone please help me?
