Hey community,
I am struggling with the running time of my simulation. If I only consider one day than everything is fine and the simulation reaches the end. But if I consider one week or even longer than the simulation is limitless. Since I can simulate one day, my code should be fine or? The main reason for the long simulation time might be the usage of the chp plant (mixed integer), but nevertheless I was expecting any results after some time, which was not possible. The running time of one night for simulating one week was not enough.
Thanks in advance for your help.
Br,
Alex
import os
import pprint as pp
from oemof.network.network import Node
solver = "cbc"
number_of_time_steps = 24 * 7
date_time_index = pd.date_range("1/1/2012", periods=number_of_time_steps,
freq="H")
# add es
energysystem = solph.EnergySystem(timeindex=date_time_index)
#Node.registry = energysystem
# add buses
brapeseedoil = solph.Bus(label="rapeseedoil")
bel = solph.Bus(label="electricity")
bheat = solph.Bus(label="heat")
energysystem.add(brapeseedoil, bel, bheat)
# add gas
energysystem.add(
solph.Source(
label="r_rapeseedoil",
outputs={brapeseedoil: solph.Flow()},
heat_extra_source = energysystem.add(solph.Source(label="heat_extra_source", outputs={
bheat: solph.Flow(variable_costs=1000000)
el_extra_source = energysystem.add(solph.Source(label="el_extra_source", outputs={
bel: solph.Flow(variable_costs=1000000)
# add heat demand
hd = [2, 2, 2, 2, 2, 2, 3, 3, 4, 4, 5, 7, 7, 5, 4, 4, 3, 3, 2, 2, 2, 2, 2, 2] * 7
#add el demand
eld = [1, 1, 1, 1, 1, 1, 4, 4, 8, 8, 10, 11, 11, 10, 8, 8, 4, 4, 1, 1, 1, 1, 1, 1] * 7
energysystem.add(
solph.Sink(
label="demand_heat",
inputs={bheat: solph.Flow(fix=hd, nominal_value=1)},
energysystem.add(
solph.Sink(
label="excess_heat",
inputs={bheat: solph.Flow()},
energysystem.add(
solph.Sink(
label="demand_el",
inputs={bel: solph.Flow(fix=eld, nominal_value=1)},
energysystem.add(
solph.Sink(
label="excess_el",
inputs={bel: solph.Flow()},
# add bhkw
bhkw = energysystem.add(solph.components.GenericCHP(
label="pp_chp",
fuel_input={
H_L_FG_share_max=[0.14 for p in range(0, number_of_time_steps)],
H_L_FG_share_min=[0.14 for p in range(0, number_of_time_steps)],
variable_costs=0.085,
electrical_output={
bel: solph.Flow(
P_max_woDH=[11 for p in range(0, number_of_time_steps)],
P_min_woDH=[6 for p in range(0, number_of_time_steps)],
Eta_el_max_woDH=[0.30 for p in range(0, number_of_time_steps)],
Eta_el_min_woDH=[0.30 for p in range(0, number_of_time_steps)],
variable_costs=0.03,
heat_output={bheat: solph.Flow(
Q_CW_min=[0 for p in range(0, number_of_time_steps)])},
Beta=[0 for p in range(0, number_of_time_steps)],
fixed_costs=0,
back_pressure=False,
pp_chp = energysystem.add(
solph.Transformer(
label="pp_chp",
inputs={brapeseedoil: solph.Flow(variable_costs=0.085)},
bel: solph.Flow(variable_costs=0.03),
bheat: solph.Flow(nominal_value=11, min=0.25, nonconvex=solph.NonConvex())
conversion_factors={bel: 0.30, bheat: 0.56},
electric_heater = energysystem.add(
solph.Transformer(
label="pp_electric_heater",
inputs={bel: solph.Flow(nominal_value=7)},
outputs={bheat: solph.Flow()},
conversion_factors={bheat: 0.90},
storage_el_lithium = energysystem.add(solph.components.GenericStorage(
nominal_storage_capacity=20,
label="storage_lithium",
outputs={bel: solph.Flow()},
loss_rate=0.00001,
initial_storage_level=0,
min_storage_level=0,
max_storage_level=1,
nominal_output_capacity_ratio=1,
nominal_input_capactiy_ratio=1,
inflow_conversion_factor=0.95,
outflow_conversion_factor=0.95,
storage_heat_puffer = energysystem.add(solph.components.GenericStorage(
nominal_storage_capacity=200,
label="storage_puffer",
bheat: solph.Flow()
loss_rate=0.004,
initial_storage_level=None,
inflow_conversion_factor=1,
outflow_conversion_factor=1,
nominal_input_capacity_ratio=1,
model = solph.Model(energysystem)
model.solve(solver=solver, solve_kwargs={"tee": True})
results = solph.processing.results(model)
electricity_bus = solph.views.node(results, "electricity")
heat_bus = solph.views.node(results, "heat")
print(electricity_bus["sequences"].sum(axis=0))
print(heat_bus["sequences"].sum(axis=0))
