Hello all,
I am trying to model energy transfer between 2 points, A and B. I use 2 Transformers for that purpose (A–>B, B–>A), since transfer losses are included. However, i have the problem that at the same time step, energy is being transfered from A to B and from B to A. Do you know how can i limit the two transfer lines so that only one of them is active at one time step?
What options do you use to model energy transfer (gas, electricity)?
Roberta
Hi @Roberta,
Typically, there should be no incentive to waste energy. So, circular flows are a sign that something is fishy with the system, i.e. the losses are actively increased. However, there is a way to implement a constraint enforcing that only one direction is possible at a time, including an example: Flow count limit — oemof.solph 0.5.1.dev3 documentation
(Note the disclaimer: “Binary variables are computationally expensive. Thus, you might want to avoid using this constraint if you do not really need it.”)
