Dear OpenMod Community,
We are working on a project for which we would like to open the data and the scripts. It would be great if someone can help in figuring out the feasible/best option for licensing the work. There is no restriction from our side.
The data has been downloaded from the source and the processing is done manually using QGIS. Thereafter the dataset is used to carry out calculations which is script based. I am planning to use MIT License for the scripts (but open to suggestion on alternatives). On the data side, I don’t know how/if it would be possible to open the processed data.
The following are the data sources and the processing done on it.
| Parameter |
Processing |
Source |
License |
| Elevation |
Rasterization, Adjust Projection |
European Environment Agency |
policy based on Directive 2003/98/EC |
| Slope |
Calculate slope, rasterize, adjust projection |
| Land Quality |
Rate fields, rasterize, adjust projection |
| Protected Areas |
rasterize, adjust projection, assign values |
ProtectedPlanet2018 |
WDPA Data Licence |
| River Courses |
Extract data, assign values, rasterize |
Geofabrik |
ODbL |
| Population density |
Rerasterize |
CIESIN; JRC |
policy based on Decision 2011/833/EU |
| Railways |
Extract data, rasterize, assign values |
Geofabrik |
ODbL |
| Highways |
Geofabrik |
ODbL |
| Electricity Grid |
Geofabrik |
ODbL |
Thanks a lot for your help.
Samarth
Dear @samarth.tu-dresden,
happy to see more and more projects going open.
We had (and will have) lots of discussions about open licenses.
I tired to collect and prepare some key information.
Please have a look at the license matrix.
Since ODbL is a copyleft (share-alike) license, I assume some parts of your work have to be relicensed with ODbL. But that’s a tricky question and depends on the processing steps of the OSM data.
I recommend to document the license flow including all copyright holders and attributions.
Hello @samarth.tu-dresden,
that is a tricky question, I am also encountering in my work. I found the FAQ of opendatacommons helpful, where they explain the difference between a license for the database and the content. In your case – which is similar to mine – I think the correct way is to license just your database and highlight the different licenses for the content.
That is what I understand from my search for this topic. Does that match with experience from others?
Best regards
Magdalena
Hey @ludwig.huelk,
Thanks for the answer and sharing the slides. Gives a good overview.
I am in discussion with Robbie on more details, and he is planning to write a detailed answer.
Samarth
Hi again,
Thanks for your various feedback on this, really helped a lot in taking the work forward. I have one more question. Since no one in my group works with GIS data, we do not really have an idea about good journals for this kind of work. Would anyone have a recommendation? The ones I looked for example International Journal of Geographical Information Science ask for a significant amount of money for the paper to be under open access.
Samarth
