Dear oemof experts,
i am trying to optimise an energysystem with a battery, a fuel cell and a power heat coupling.
My problem ist, that oemof optimise the fuel cell and the power heat coupling bigger as it could be realistic. I think the result would be better, when oemof consinders the OPEX (operational costs in the for example 20 years lifetime).
Is this atm possible?
# Invest Batterie Definitionen
capexbat = 563 # investment cost
lifetime = 20 # life expectancy
wacc = 0.001 # weighted average of capital cost
epc_bat = capexbat * (wacc * (1 + wacc) ** lifetime) / ((1 + wacc) ** lifetime - 1)
#Batteriespeicher
energysystem.add(solph.components.GenericStorage(label='Batterie',
inputs={bel: solph.Flow()},
outputs={bel: solph.Flow()},
nominal_input_capacity_ratio=0.35,
nominal_output_capacity_ratio=0.35,
capacity_loss=0.001,
inflow_conversion_factor=0.95,
outflow_conversion_factor=0.95,
investment=solph.Investment(ep_costs=epc_bat)))
# P2G und KWK #
# Gas und Wärme Bus initialisieren
bgas = solph.Bus(label="gas")
energysystem.add(bgas)
bheat = solph.Bus(label="heat")
energysystem.add(bheat)
# Gassenke
energysystem.add(solph.Sink(label='Gaseinspeisung', inputs={bgas: solph.Flow(
variable_costs=-0.03)}))
# Gasquelle
energysystem.add(solph.Source(label='Gasbezug', outputs={bgas: solph.Flow(
variable_costs=0.0615)}))
# Netzüberschuss, Einspeisung
energysystem.add(solph.Sink(label='Heatsink', inputs={bheat: solph.Flow(
variable_costs=-0.01)}))
# Invest P2G Definitionen
capexbsz = 1220 # investment cost
epc_ptg = capexbsz * (wacc * (1 + wacc) ** lifetime) / ((1 + wacc) ** lifetime - 1)
# Power 2 Gas
energysystem.add(solph.Transformer(
label="P2G",
outputs={bgas: solph.Flow()},
conversion_factors={bgas: 0.58},
investment=solph.Investment(ep_costs=epc_ptg)))
# Invest KWK Definitionen
capexbsz = 1000 # investment cost
epc_kwk = capexbsz * (wacc * (1 + wacc) ** lifetime) / ((1 + wacc) ** lifetime - 1)
# KWK
label="KWK",
inputs={bgas: solph.Flow()},
outputs={bel: solph.Flow(),
bheat: solph.Flow()},
conversion_factors={bel: 0.40, bheat: 0.45},
investment=solph.Investment(ep_costs=epc_kwk)))
#Gasspeicher
energysystem.add(solph.components.GenericStorage(label='Gasspeicher',
inputs={bgas: solph.Flow(nominal_value=1000)},
outputs={bgas: solph.Flow(nominal_value=1000)},
nominal_value=20000,
nominal_capacity=20000,
capacity_loss=0.0001,
inflow_conversion_factor=0.98,
outflow_conversion_factor=0.98))
# initialise the operational model (create problem)
om = solph.Model(energysystem)```
