I was wondering what is the correct way to proceed to perform an investment optimization on, say a transformer with 1 input and 2 outputs?
Using the example from the oemof-solph docs:
b_gas = solph.buses.Bus(label='natural_gas')
b_el = solph.buses.Bus(label='electricity')
b_th = solph.buses.Bus(label='heat')
solph.components.Transformer(
label='pp_chp',
inputs={b_gas: Flow()}, # should I put the Invesment here
outputs={b_el: Flow(nominal_value=30), # or here?
b_th: Flow(nominal_value=40)}, # here as well ?
conversion_factors={b_el: 0.3, b_th: 0.4})
I would tend to think it doesn’t make sense to have more Investment object than component, so I would be tempted to write it in the input, or in one of the output, then which one?
I could not find an answer in the examples nor in the documentation of oemof-solph
Thanks in advance for your answer
