Hello all,
I am trying to model a pit thermal storage filled with water which I assumed would be be modeled using a StratifiedThermalStorage from oemof.thermal.
In the documentation here I find the following:
Collapsible code block
from oemof.solph import Bus
from oemof.thermal.facades import StratifiedThermalStorage
bus_heat = Bus('heat')
thermal_storage = StratifiedThermalStorage(
label='thermal_storage',
bus=bus_heat,
diameter=2,
height=5,
temp_h=95,
temp_c=60,
temp_env=10,
u_value=u_value,
min_storage_level=0.05,
max_storage_level=0.95,
capacity=1,
efficiency=0.9,
marginal_cost=0.0001
which contains the parameters volume and min and max temperature which I wanted to use.
However, when I use
energysystem.add(StratifiedThermalStorage(
label='PTES',
I get the following (conflicting) documentation info in PyCharm:
Meaning, I cannot use most of the relevant parameters mentioned in the Stratified thermal storage documentation. When I try using e.g. ‘volume’ or ‘temp_h’, I get error messages:
Error message
File “C:\Users\xxx”, line 203, in
File “C:\Users\User\AppData\Local\Programs\Python\Python312\Lib\site-packages\oemof\thermal\facades.py”, line 242, in init
Facade.init(
File “C:\Users\User\AppData\Local\Programs\Python\Python312\Lib\site-packages\oemof\thermal\facades.py”, line 79, in init
super().init(*args, **kwargs)
TypeError: Node.init() got an unexpected keyword argument ‘volume’
If I cannot use the temperature and volume parameters, what is the point of using StratifiedThermalStorage instead of GenericStorage? And does anyone know what the problem here may be?
I use oemoph.solph version 0.5.2 and oemof.thermal version 0.0.6
Thanks and best regards,
Ella
