Dear community,
I model a power plant with a set of turbines including a back pressure turbines like this:
turb2 = solph.components.GenericCHP(
label='back_pressure_turbine2',
fuel_input={coal_bus: solph.Flow(H_L_FG_share_max=[0.05 for p in range(0, periods)])},
electrical_output={el_bus: solph.Flow(P_max_woDH=[30000 for p in range(0, periods)],
P_min_woDH=[0 for p in range(0, horizon_length)],
Eta_el_max_woDH=[0.23 for p in range(0, periods)],
Eta_el_min_woDH=[0.23 for p in range(0, periods)])},
heat_output={heat_bus: solph.Flow(Q_CW_min=[0 for p in range(0, periods)])},
Beta=[0 for p in range(0, periods)],
back_pressure=True)
Could you please tell me if it is possible to force the turbine to keep working and to forbid to switch off during all the calculation period? I tried different options like Nonconvex, offset_transformer but they didn’t work properly. Thank you in advance!
Lenar
