Dual error warning
Dear people,
I get this warning from the solver, which says that there is something wrong with dual values. I get the dual values in my result data frame. But I do not understand if this warning makes sense or not. Does anybody have a similar experience with this?
WARNING: Reassigning the non-component attribute dual on block (model).Model
    with a new Component with type <class 'pyomo.core.base.suffix.Suffix'>.
    This is usually indicative of a modelling error. To avoid this warning,
    explicitly delete the attribute:
        del Model.dual
10:13:34-WARNING-Reassigning the non-component attribute dual
on block (model).Model with a new Component
To avoid this warning, explicitly delete the attribute:
    del Model.dual
WARNING: Reassigning the non-component attribute rc on block (model).Model
        del Model.rc
10:13:34-WARNING-Reassigning the non-component attribute rc
    del Model.rc
Set parameter Username
Academic license - for non-commercial use only - expires 2024-03-11
Read LP format model from file C:\Users\mallad\AppData\Local\Temp\tmpxnripj9t.pyomo.lp
Reading time = 0.36 seconds
x127059: 135805 rows, 120489 columns, 391680 nonzeros
Set parameter QCPDual to value 1
Gurobi Optimizer version 10.0.1 build v10.0.1rc0 (win64)
I wish you a nice weekend ahead.
Best Regards,
Dev
