Hi everyone,
I’m currently implementing peak shaving in an oemof model.
For this I add a max_power variable for each month within the simulation horizon.
For each timestep I add a constraint to limit the sum of the flows from the grid into my system (there are several grid sources due to different energy markets) to the corresponding max_power variable.
The max_power variables afterwards are multiplied with cost_per_watt and added to the objective function. So far everything works well (at least it seems to work as the objective of the optimizer changes in a reasonable way if the feature is activated).
model.CustomConstraints.PEAK_SHAVING.max_power_set = po.Set(initialize=range(1, 1 + len(monthly_indices)))
model.CustomConstraints.PEAK_SHAVING.max_power_indexed = po.Var(model.CustomConstraints.PEAK_SHAVING.max_power_set, within=po.NonNegativeReals)
Unfortunately, I struggle with the result processing part of oemof as oemof tries to restructure all results of the optimizer into a (start_component, end_component) logic, which fails for my max_power variables.
File "C:\Users\user\AppData\Local\anaconda3\envsoemof_env\Lib\site-packages\oemof\solph\processing.py", line 162, in set_result_index
df_dict[k].index = result_index
File "C:\Users\user\AppData\Local\anaconda3\envsoemof_env\Lib\site-packages\pandas\core\generic.py", line 6307, in __setattr__
return object.__setattr__(self, name, value)
File "properties.pyx", line 69, in pandas._libs.properties.AxisProperty.__set__
File "C:\Users\user\AppData\Local\anaconda3\envsoemof_env\Lib\site-packages\pandas\core\generic.py", line 813, in _set_axis
self._mgr.set_axis(axis, labels)
File "C:\Users\user\AppData\Local\anaconda3\envsoemof_env\Lib\site-packages\pandas\core\internals\managers.py", line 239, in set_axis
self._validate_set_axis(axis, new_labels)
File "C:\Users\user\AppData\Local\anaconda3\envsoemof_env\Lib\site-packages\pandas\core\internals\base.py", line 98, in _validate_set_axis
raise ValueError(
ValueError: Length mismatch: Expected axis has 3 elements, new values have 961 elements
I think the definition of the variables is not the way you’re supposed to do this in oemof.
How can I add a set of new variables to the model after the pyomo model is generated by oemof in a way that oemof can deal with the result?
Thanks for your ideas!
Best regards
Brian
(Btw: I don’t want to add grid components for every month to keep the model simple)
