Problem with Generic Storage in a multiperiod-model
I am currently working on a multiperiod-model of a single-family household.
My model contains a heat and battery storage. For both storages I choose the balance to be true, so the storage content at beginning and the end of each period should be the same.
It turned out that this is not the case in the results of my model .
I then assumed that the balanced=True command only influenced the beginning and ending of the first- and last-time interval of the whole optimization, regardless of the periods.
The results did not verify my assumed explanation, as the storage content in the first interval showed that the storages were charged to their maximum capacities and in the Last interval they were emptied out.
So, for my model setting the storages balanced=true had no effect whats ever.
The model in which I initially ran over the issue is rather complex.
I created a minimalistic example that contains an electricity source, a storage and an electricity sink as a multiperiod model with two periods, each period is one year (8760 h) long.
In that minimalistic model the same problem accord.
The code and the input data as below.
#minimalistic example
import os
import oemof.solph as solph
from pyomo.environ import Constraint
from pyomo.environ import SolverFactory
# %% (Daten einlesen)
file_path = os.path.dirname(__file__)
file_name = os.path.join(file_path, "input_data_minimalbeispiel.csv")
data = pd.read_csv(file_name, sep=";", decimal=".")
data["date"] = pd.to_datetime(
    data["date"],
    format="%d.%m.%Y %H:%M"
data = data.set_index("date")
full_index = pd.date_range(start="2027-01-01", end="2028-12-31 23:00", freq="h")
full_index = full_index[~((full_index.month == 2) & (full_index.day == 29))]
data.index = full_index
# %% (Perioden: 2 volle Jahre)
periods = [
    data.loc["2027"].index,
    data.loc["2028"].index,
energy_system = solph.EnergySystem(
    timeindex=data.index,
    timeincrement=[1] * len(data.index),
    periods=periods,
    infer_last_interval=False,
# %% (Komponenten)
ac_bus = solph.Bus(label="ac network")
energy_system.add(ac_bus)
grid = solph.components.Source(
    label="grid",
        ac_bus: solph.Flow(variable_costs=data["el spot price"])
energy_system.add(grid)
demand = solph.components.Sink(
    label="electricity demand",
    inputs={
        ac_bus: solph.Flow(nominal_capacity=1, fix=data["electricity demand"])
energy_system.add(demand)
battery = solph.components.GenericStorage(
    label="battery",
    inputs={
        ac_bus: solph.Flow(
            nominal_capacity=solph.Investment(ep_costs=0, maximum=10, lifetime=15)
        ac_bus: solph.Flow(
    nominal_storage_capacity=solph.Investment(
        ep_costs=100, maximum=20, lifetime=15
    inflow_conversion_factor=0.95,
    outflow_conversion_factor=0.95,
    loss_rate=0,
    balanced=True,
energy_system.add(battery)
# %% (Modell und Loesung)
model = solph.Model(energy_system)
print("\nConstraints im GenericInvestmentStorageBlock:")
blk = model.GenericInvestmentStorageBlock
for c in blk.component_objects(Constraint):
    print(" ", c.name, "-> Anzahl Eintraege:", len(c))
blk.initially_empty.deactivate()
solver = SolverFactory("gurobi")  # ggf. auf "cbc" o.ae. aendern
solver_results = solver.solve(model, tee=True)
results = solph.processing.results(model)
# %% (Auswertung)
soc = results[(battery, None)]["sequences"]["storage_content"]
t_boundary = len(periods[0])  # erster Zeitschritt von Periode 1
print("\nInvestierte Kapazitaet je Periode:")
for p in range(len(periods)):
    invest_p = model.GenericInvestmentStorageBlock.invest[battery, p].value
    print(f"  Periode {p}: {invest_p:.3f} kWh")
print("\nSpeicherfuellstand (Batterie):")
print("  Start (t=0):                 ", round(soc.iloc[0], 3))
print("  Periodengrenze (Jahreswechsel 2027/2028):", round(soc.iloc[t_boundary], 3))
print("  Ende (letzter Zeitschritt):  ", round(soc.iloc[-1], 3))
Inputdata: input_data_minimalistic_model · GitHub
Hi @ArminHoffmann,
thanks for bringing this up. Please note that multi-period is experimental, thus the behaviour is not consistent between releases, and also much of it is not unit-tested. On the positive side, this leaves room for design decisions that might be helping you.
For “productive” use, we currently recommend using version 0.5.7, as it was the basis for a PhD thesis so that it was checked more carefully. That version assumes that newly invested storages are always empty, so that balanced=True does not really make sense. As you deactivated initially_empty, I would expect inconsistencies.
One problem with this implementation is that other parts of the code assume continuous time. To preserve maintainability, we decided to remove special case handling and now move to a continuous time model also for long-term investment models. With the 0.6-releases, we slowly patched out hard-coded calculations for discounting and other multi-period specific functionality. Not all are replaced by adequate alternatives, yet.
Considering your feedback, I think that decoupling time-steps is a wanted feature, and it could be realised using the mechanism for representative periods originally proposed for temporal aggregation. I just put that to the agenda of our weekly dev JF.
Regards,
