Hi
I would like to analyze nodes parameters after the optimization by means of the param_results method in outputlib.processing, but I get the error:
AttributeError: module 'oemof.outputlib.processing' has no attribute 'param_results'
why do I get such error even if the method is actually in the processing.py script?
Thanks!
Gabriele
Could you provide more information.
For me it works like this:
from oemof import outputlib
param_dict = outputlib.processing.param_results(my_valid_energysystem)
I solved it…
I had installed the oemof version 0.2 and the command didn’t work (I had written it correctly). I updated to v0.2.2 and it worked.
Be aware that it is renamed from param_results to parameter_as_dict (as parameters are no results but input values). Both will work until v0.3 but you should use parameter_as_dict to avoid warnings and problems in the future.
