Hello oemof community,
I try to model the dispatch of various heat generators in a district heating system. In the following minimal example, I only have a coal-fired CHP and gas boilers. I already successfully implemented constraints such as startup costs and minimum downtime restrictions in order to have a more realistic dispatch. I struggle with implementing an availability constraint and think that the limit_active_flow_count method is the thing I’m looking for.
However, it does not work as I want. In the minimal example with 100 timesteps I want to restrict the coal CHP to be available in only 80 hours. (sum of status variables <= 80) In the output graphic can be seen that the coal CHP is running all the time and that the restriction is not working properly. (sum of status variables = 100) I assume the error is in line 95, but I can’t help myself anymore. Any help appreciated
Thanks
from oemof.solph import constraints
from oemof.network.network import Node
try:
except ImportError:
plt = None
d = {'heatload': [569.894450, 554.2135219,576.837488,592.7529451,618.0502412,632.558263,678.3786056,726.6801345,806.329521,848.8491301,843.8206541,813.0734607,807.3272522,778.3711548,778.4368546,784.8020551,779.5431271,761.8519632,777.5371374,761.8624275,726.3735687, 675.0647848, 618.6561332, 554.6097775, 513.7508669, 539.4350185, 535.7783665, 529.6785499, 549.5875261, 574.5496884, 600.239436, 637.075229, 628.5732578, 601.4101048, 541.8661765, 588.8839689, 598.4106573, 606.8333384, 617.5686688, 639.4357284, 632.9272146, 655.3578554, 702.1020292, 706.0926676, 652.98615, 640.1256493, 582.4460837, 545.8409157, 506.8142917, 472.7983128, 476.7137177, 510.0998035, 550.6710718, 581.9813453, 634.0033481, 686.6767652, 727.9725173, 757.7538129, 767.6656191, 736.8802585, 719.4589034, 715.998717, 707.87435, 727.4863255, 737.984244, 760.8643837, 787.3455427, 791.1650559, 765.8598904, 705.039758, 667.8975652, 609.6473977, 581.9407515, 566.2968668, 556.7446213, 568.0255219, 592.5596927, 641.3621953, 696.5671288, 731.2254129, 765.7689387, 791.0106244, 780.5576145, 738.871454 ,703.7412025, 694.3974001 ,691.4191767 ,731.6054528, 756.4210631 ,780.9160513, 787.4793288 ,761.8624275, 751.0210896 ,703.7914218, 686.5752325 ,629.104551 ,569.4304585 ,555.1185683, 564.725173, 589.2807187],
'elprice': [23.86, 22.39, 20.59, 16.81, 17.41, 17.02, 15.86, 18.16, 17.73, 19.77, 23.75, 26.03, 27.06, 26.59, 25, 24.43, 28.87, 37.44, 37.41, 35.34, 33.07, 29.52, 30.1, 24.57, 22.2, 16.57, 15.35, 12.77, 11.27, 11.91, 12.62, 13.83, 16.12, 18.12, 19.59, 21.07, 22.54, 19.79, 16.9, 16.97, 19.25, 28.01 ,28.36 ,26.56 ,17.38 ,15.83, 16.97, 15.31, 6.99, -0.01, 0.23, 4.51, 4.12, 6.76, 0.75, 4.27, 9.11, 15.92, 17.06, 19.28, 20.25 ,17.66 ,18.49 ,16.51, 18.76 ,22.21 ,26.76 ,27.08, 25.33, 22.11, 20.91 ,14.43, 13.78, 12.77 ,10.56, 3.87, 3.2, 8.67, 18.01, 28.52 ,34.74 ,33.46 ,33.24, 35.09 ,35, 35 ,34.94, 34.92, 38 ,41.21, 42.95, 41.96, 34.94, 30.66 ,30, 23.9, 22.34, 17.93, 15.17 ,16.38]}
data2 = pd.DataFrame(data=d)
# select periods
periods = len(data2)
# create an energy system
idx = pd.date_range("1/1/2015", periods=periods, freq="H")
es = solph.EnergySystem(timeindex=idx)
Node.registry = es
#fuel cost
ccoal= 12.5
cgas = 20
#Emission pricing
cprice = 8
efgas = 0.2
efcoal = 0.337
# resources gas, coal, waste
bgas = solph.Bus(label="natural gas")
rgas = solph.Source(label="natural gas market", outputs={bgas: solph.Flow(variable_costs = cgas + cprice*efgas)})
bcoal = solph.Bus(label = "hard coal")
rcoal = solph.Source(label = "hard coal market", outputs = {bcoal: solph.Flow(variable_costs = ccoal + cprice*efcoal)})
# heat bus
bheat = solph.Bus(label="heat")
#heat load profile that needs to be served
demand_th = solph.Sink(
label="demand_th",
inputs={bheat: solph.Flow(fix=data2['heatload'], nominal_value = 1)},
# power bus
bel = solph.Bus(label="electricity")
demand_el = solph.Sink(
label="demand_el",
inputs={bel: solph.Flow(variable_costs=-1*data2['elprice'])},
# coal CHP
coal_chp = solph.components.GenericCHP(
label="coal_CHP",
fuel_input={
bcoal: solph.Flow(H_L_FG_share_max=[0.1 for p in range(0, periods)],
nonconvex=solph.NonConvex(startup_costs=60*31, minimum_downtime=4, initial_status=1),
nominal_value=194/0.39,
min= 60/194*0.39/0.35,
max= 1
electrical_output={
bel: solph.Flow(
P_max_woDH=[194 for p in range(0, periods)],
P_min_woDH=[60 for p in range(0, periods)],
Eta_el_max_woDH=[0.39 for p in range(0, periods)],
Eta_el_min_woDH=[0.35 for p in range(0, periods)],
heat_output={bheat: solph.Flow(Q_CW_min=[15 for p in range(0, periods)])},
Beta=[0.16 for p in range(0, periods)],
back_pressure=False,
# gas-fired heat-only plants
gas_boilers = solph.Transformer(
label ="Gas boilers",
inputs = {bgas: solph.Flow(nonconvex=solph.NonConvex(startup_costs=10*70),
nominal_value=700/0.88,
min= 0.01,
max= 1)},
outputs = {bheat: solph.Flow(max = [700 for p in range(0, periods)], nominal_value=1)},
conversion_factors = {bheat: 0.88}
# create an optimization problem and solve it
om = solph.Model(es)
om = constraints.limit_active_flow_count(om, 'availability', [(bcoal, coal_chp)], lower_limit=0, upper_limit=80)
# solve model
om.solve(solver="gurobi", solve_kwargs={"tee": True})
# create result object
results = solph.processing.results(om)
# plot data
if plt is not None:
# plot thermal bus
data = solph.views.node(results, "heat")["sequences"]
data.columns = ['gas boilers', 'coal CHP', 'Demand']
ax = data.plot(kind="line", drawstyle="steps-post", grid=True)
ax.set_xlabel("Time (h)")
ax.set_ylabel("Q (MW)")
plt.show()
I somehow successfully created an availability constraint with the
